Readiness codes on Turbo setup! Flashpro
Anyone have any idea how long it takes the readiness monitors for emissions to complete when enabled in Flash Pro? I am going to be enabling the secondary o2 sensor and EVAP system so the car can pass emissions, but I heard it takes a few hundred miles to complete.
Former Sponsor
The procedure to set the readiness codes is outlined in the Honda manual. There are some pretty specific conditions, and it is possible that you could drive 10,000 miles and still not set the readiness codes. For some tests the IAT and ECT need to be within a certain temperature range when the vehicle is started. For other tests the ECT and IAT must be almost the same when started. Other tests require a steady throttle at a certain speed range for a certain time. There are hoops to jump through.
Can you guys please make it an option to force readiness in the next Flashpro update. I know thats an option with K-pro and you guys are not offering kpro for the 2006-2009 cars anymore.
I'm stuck in the same boat.... And the only thing not carb legal is my test pipe. I'm SC and even with the cat on the readiness codes won't complete. Like 8k invested in carb legal pArts and I still can't pass........ Come on hondata
Same boat, it sucks see my thread on the subject:
https://www.s2ki.com/s2000/topic/109...ting-flashpro/
