PLX
Which PLX gauge? The SM-AFR? If so, the answer is yes, but the output would be analog only.
Why not use an AEM Wideband Failsafe? You can wire it digitally to the EMS using the AEMnet and get a lot more functionality.
http://www.aemelectronics.com/wideba...safe-gauge-84/
http://www.aemelectronics.com/Images...%2030-4900.pdf
Tim
Tim
I have a PLX sensor wired into my AEM EMS. I use the AEM multi-gauge though. I dont see why it wouldnt work, its just a signal wire and you input the resistance or something like that into the EMS software. Im pretty sure almost any wideband can provide the EMS with the data it needs. I remember there being a dropdown box with multiple manufacturers and a custom drop down where you input parameters for whatever sensor your using.
