Miss fire code saturated plugs
Hello guys
So have a miss fire code and the plugs are saturated. S2k has a test pipe with o2 sensor fouler installed. Could this be the issue? I'm thinking it needs a tune but doesn't have a computer installed. Any thoughts? Thanks
If they are saturated with oil that could be your cause for misfire.
It isn't due to the test pipe, many run a test pipe on the OEM ECU without issue.
