HELP! KPro Sensor Install
Help. Hondata says all you need is a new crank sensor harness, but the new cam sensor I installed (per Hondata's website) has a 3 prong female end and my MY02 has a 2 prong female connector. I cannot find anywhere where anybody has changed this wiring harness. Did I get sent the wrong cam sensor?
Ok, more help needed. I finally received the sensor harness wire from the seller I bought the Kpro from. Of course, I have no instructions, so I need to know which plug goes to which sensor. The harness is bundled together and has a sensor plug 2/3 of the way down and then has a sensor plug at the end. Which one goes to the cam sensor and which one goes to the crank sensor?
