Help with aem 1052u wideband afr
So I installed my ems and uploaded the base map. I am running the 1052u with aem uego gauge and I have the 0-5 v wire tapped into the c16 pin. The problem that I am running into is that my ems is not reading the same as the gauge. It actually doesn't move at all in aempro. I have changed the afr units to gasoline. Check my wiring and it's good. I don't know about the volts that's it's reading. So I can't datalog without it reading wrong afrs
I’d suggest checking the calibration screw position on the back of the gauge. The gauge can emulate different output types depending on the position of the screw. It should be at P0 or P1 for the wideband output. If it’s not this might cause the problem you describe.
