Haltech ps1000
Haltech ps1000
Hey guys I recently decided to go turbo from s/c and I opted to ditch the oem o2 sensor and use the aem wideband and new sensor instead. I am after help to wire it up, and in the process also wire up the Mac boost solenoid. The tuner can configure whatever is needed the main thing is to have them ready to keep the costs down.
Thanks guys,
Manny.
Thanks guys,
Manny.
you need the auxiliary harness to wire up the wideband to the pro plug in ecu. as far as the boost solenoid, remember that the ecu comes in with a built in map sensor. it can read ~22 psi.
Diddy
08-14-2002 10:07 AM
