Flickering CEL with AEM EMS
Member
I noticed when driving the other day that the CEL was flickering a bit, just under normal driving.
I then noticed it again when I was on track.
I've been advised by Mase that it's the coolant temp getting too high.
Has anyone else had this?
I guess I have to plug the AEM cable in and do some logging?
What you doing over here
FWIW Mark, Have you checked with Mase or can you access the settings with a laptop (Doubt it would be difficult TBH)?, I know with DTA ECU's you can set the CEL light to come based on different parameters I guess its the same with an AEM. For example you can set it to come engage when temp reach a particular level etc, or in your case possibly 'knock' hence the flickering?
trivium
08-28-2007 06:23 PM
