Flashpro w/ aem wideband question?
Old 07-06-2014, 06:57 PM
SLWS2K's Avatar
Yeah this is great info! Thank you for posting it... it seems like I've spent weeks trying to find info like this.
Old 07-06-2014, 09:14 PM
crxdx's Avatar
Anytime. Need anything else just let me know.
Old 07-12-2014, 05:06 PM
SLWS2K's Avatar
I finally got some time to get this thing hooked up. I soldered the wire to the ELD input and set it up in flashpro just like the picture but now I'm getting a p0135 code for heated oxygen sensor malfunction. How do I get this to go away? Did anyone else have this problem?
Old 07-12-2014, 08:13 PM
crxdx's Avatar
Did you disable (uncheck) your ELD and set your wideband input source to the ELD location?
Old 07-14-2014, 05:58 AM
SLWS2K's Avatar
I'm pretty sure I did..... I'll check it out tomorrow and check back in.
Old 07-15-2014, 08:23 AM
SLWS2K's Avatar
Yeah I did it just like the pics you loaded.. I also tried reloading the Cal a few times just to make sure it took. Any other ideas?
Old 07-15-2014, 11:25 AM
SLWS2K's Avatar
Well I'm cruising the car around today and the oxygen sensor stopped reading... All I get is the flat lines going across the gauge and it'll randomly read here and there and go back to the flat lines. It sucks I've maybe driven 100 miles on it. Any idea what the bosch replacement sensor part # is? It might be easier just to buy one then to get it warrantied
Old 07-15-2014, 07:29 PM
crxdx's Avatar
I can get you the bosch replacement sensor for the aem uego when I get home
Old 07-22-2014, 12:42 PM
SLWS2K's Avatar
Any luck on finding that part #
Old 08-06-2014, 10:48 AM
EK9MAX's Avatar
Which pin should I run if I don't want to replace the stock sensor?
Quick Reply: Flashpro w/ aem wideband question?
