FlashPro O2 cat delete
Old 02-02-2010, 11:53 AM
  #61
dedonderosa's Avatar
so basically whats the deal with this?? is this prob fixed now? I dont see how people with brand new cars are getting this cel for the o2... having there sensor be bad....
Old 02-02-2010, 02:29 PM
  #62
crazysupratt's Avatar
you know what is strange, the other day I uploaded the Stock - Tuned map into my car just to test it out. When it finish loading normally, I go to start the car and notice that not all the sensors are showing up. I thought oh crap, what happen. I notice it because when I hit Datalog, nothing was datalogging. I then shut off the car and uploaded my old map that I originally had in the car and it worked out fine. All the sensor showed up and datalogging was working correctly.
Just want to put that out there. I'll try again to upload the stock - tuned map and see what happens.
Old 02-03-2010, 03:23 PM
  #63
man i'm getting weird things happening with the stock calibration. After it uploads, I tried to datalog and it wouldn't datalog. So I disconnect the unit and restart the application and then it would start datalogging.
I don't have this issue when I use my tune map. After I make correction and upload the ecu, I hit the datalog and it would start datalogging. I didn't have to unplug the usb or restart the application.
Its just strange...
Old 02-04-2010, 03:41 AM
  #64
honestly what the hell is goin on with flashpro?
Old 02-04-2010, 08:03 AM
  #65
i'm thinking it was just a flute. I'll try it again and see what happens.
Old 02-04-2010, 08:42 AM
  #66
i just dont see how brand new cars are havin the o2 fail like that ya know
Old 02-04-2010, 09:19 AM
  #67
macr88's Avatar
It does seem a bit odd but Honda does have a TSB out for it. I put my cat back in and I still get the code.
I won't take the car to the dealer, too many problems in the past with dealers causing damage and denying it.
But at the same time I'd hate to spend 180 bucks on something that could be free.
Now would be a nice time to have a friend at a dealership.
Old 02-04-2010, 10:05 AM
  #68
yea but its just weird..... car driving fine no cel------> reflash------>then cel..... seems like to many coinky dinks ..
Old 02-04-2010, 10:37 AM
  #69
alSpeed2k's Avatar
^FWIW, a friend with a stock 2007 had his O2 fail fairly recently. He had it replaced and the the mechanic said it's not that uncommon.
Old 02-08-2010, 10:18 AM
  #70
Former Sponsor
Gernby's Avatar
I removed the mechanical secondary O2 fix from my test pipe 9 days ago, but did NOT disable the secondary sensor using my FlashPro. I expected to get a CEL pretty quickly, but I haven't yet. I'm not sure if this has any direct relation to the topic of this thread, but I thought it was interesting. My test pipe is a T1R 63 mm with built in resonator.
Quick Reply: FlashPro O2 cat delete
