FlashPro O2 cat delete
#101
Originally Posted by glagola1,Mar 17 2010, 09:19 AM
My CEL is not fixed. If I don't hit VTEC at partial throttle, the cell wont' come on. It seems to pop up if I cross into VTEC under part throttle.
#104
Originally Posted by scors2,Mar 17 2010, 04:20 AM
does your state require obd readiness for inspection? If it does how does your car see the rear o2 as per readiness state. N/A, inc or complete. In N.Y. we have a plug in inspection and i have a flash pro on the way i plan to use this feature just wanted to know if ill pass.
#105
Originally Posted by glagola1,Mar 17 2010, 07:51 AM
I'm getting P2A00. The 02 has not been replaced.
#107
Originally Posted by Black Nugget,Jan 7 2010, 09:19 AM
I've had the same CEL come up in my S2000 and we confirmed today that it was due to a bad Primary o2 Sensor.
Just FYI, Honda has a TSB out for this code.
January 27, 2007
MIL Is On With DTC P1172 or P2AOO
SYMPTOM
The MIL is on with PGM-FI DTC P1172 (air fuel sensor [sensor 1] circuit out of range, high) and/or P2A00 (air fuel sensor [sensor 1] circuit range/performance problem).
PROBABLE CAUSE
The air/fuel sensor is damaged by moisture in the exhaust system during engine warm up.
CORRECTIVE ACTION
Use the HDS to update the ECM/PCM PGM-FI software. Replace the air/fuel sensor.
PARTS INFORMATION
Air/Fuel Sensor:
S2000:P/N 36531-PZX-003, H/C 8199630
Mine has been throwing that code quite a bit lately, random reasons... took it to my Honda shop today and they are replacing it tomorrow.
January 27, 2007
SYMPTOM
PROBABLE CAUSE
CORRECTIVE ACTION
PARTS INFORMATION
Air/Fuel Sensor:
Matt, I told you to get this replaced! You will be very happy when you do
#108
After going through the manual in detail it is very apparent that a decent working o2 sensor is important for this car. Even during WOT it is check a/f and making adjustments!
#109
