Flashpro on an AP1. Is it possible?
Is it possible to convert an AP1 F20C to work wit a flashpro? Like maybe converting it into DBW and probably, use an ap2 ECU?
Or is Hondata currently making a way to tinker wit AP1s using a flashpro? thanks guys.
This has been covered before; the 2005 and earlier ECU does not use flash memory - is not re-programmable.
To upgrade to a FlashPro you would essentially need the whole wiring harness of an AP2 (engine harness, under dash harness, throttle controller, o2 sensor wiring, diagostic connector ...) plus the DBW throttle pedal & throttle body and the engine sensors from the 2006+ (crank and cam sensors, valve cover). There may be some more items, but I think you get the idea - you'd need a donor 2006+ and then swap everything over to the earlier chassis.
Originally Posted by 96-EJ6,Apr 13 2010, 08:43 PM
K-Pro for 00-05's
FlashPro for 06-09's
Capabilities and features are nearly identical.
To the OP, it's probably not worth the trouble to completely convert your car over to the DBW-spec S2K...it's seriously a lot of trouble you'd put yourself through just to be able to run a FlashPro.
If you were looking to go with a Hondata tuning solution for your AP1, then the only route you can go is with a K-Pro.
Originally Posted by ap1_tot,Apr 20 2010, 09:38 AM
Okay thanks sirs. Downside of the K-pro though is it costs x3 the price of the Flashpro haha
s2ksang
02-26-2009 09:45 AM
