Emanage Ultimate
Emanage Ultimate
I may be buying a Emanage ultimate to tune my comptech kit, with 550cc Rc's and 10psi...
Will i need the greddy (boost) pressure sensor?
What is it used for?
Technically, yeah, they should interpolate properly. You know, 0V at idle (negative pressure), and 5V at 3bar, accordingly.
If you can, buy the greddy or a GM MAP. It's better to run ignition timing off of load, instead of RPM.
Hey, I was thinking, these digital Vac/Boost gauges that come with their pressure sending unit, they're 5V, aren't they? Maybe you can tap into it for greddy ultimate.?
s2konroids
10-04-2010 07:01 AM
