Does 07 ap2 have exhaust gas temp?
Originally Posted by s2kmiami69,Feb 14 2011, 09:30 AM
electronic load detector and engine coolant temp...i didnt know and was curious so i looked it up and thats what google told me
Originally Posted by gernby,Feb 14 2011, 10:56 AM
I guess I should have been more clear. I know what the acronyms are. I just don't know what value they have. What would the OEM ECU do with either input?
Kpro only has one aux input for datalogging and that's the ELD input. Boost controller runs off a spare purge valve output. The ELD input probably does exactly what it sounds like - measures electrical load. Why? I have no idea. A quick google search might yield a result or two.
As for the 06+ dual ECT sensors...I would imagine its to compare coolant temp coming in and out of the radiator. I'm sure there's some fancy temp compensation going on depending on the delta between the two readings
