Does 07 ap2 have exhaust gas temp?
Hi guys, just wondering if the 07 ap2 has an exhaust gas temp sensor. I am planning to flashpro my cat then track it but I'm not sure if the a/f ratio will be too aggressive when coupled with the heat I face on the track (>50 deg C track temp).
Does the stock ap2 have an EGT sensor? Is there a memory on it to read what was previous EGT experienced?
Apologise for the newbie questions. I dunno much abt ecu's
Originally Posted by gernby,Feb 12 2011, 06:54 AM
It has a wideband O2, but no EGT. However, I believe it would be simple to install an aftermarket EGT, and datalog it using the FlashPro.
Originally Posted by spectacle,Feb 12 2011, 08:06 AM
06+ ECU has open inputs for external sensors?
