Another Tunerview II install option
Originally Posted by gernby,Jan 11 2011, 05:16 PM
Yes, but why would you want to leave the FlashPro AND laptop hooked up all the time?
Originally Posted by spectacle,Jan 12 2011, 09:25 AM
You wouldn't. You would want a display that shows you all the paramaters that FlashPro can see without the laptop. That's what the TunverView can do.
Why not just get something like a Dash Hawk?
The main advantage for using the TV2 over an OBDII display is update frequency and the option to display anything from the KPro that's not in the OBDII spec.
But for someone running FlashPro it's not an option. Plug in displays are fine, though, for the most part but you do notice how much more sluggish they update compared side by side with the TV2.
When you use the FlashPro to datalog, it is doing so via OBDII. However, it is using the latest OBDII standard, which utilizes CANBUS. The data rate is MUCH faster than what the KPro puts out. If you get a current generation OBDII display that supports the latest OBDII standard, it will have very fast update rates too. When you use the FlashPro and a laptop to datalog, you are effectively just using the FlashPro as a CAN-to-USB dongle.
I REALLY doubt the '00-'05 S2000's support CAN, so they would provide slow data updates. The old prodocol required the datalogger to request each piece of data, then wait for the ECU top send it. However, all cars were required to support CAN beginning in '08, and the S2000 got it in '06. I'm not certain about the data rate on the S2000's CAN, but my Lexus was pumping data at about 1 Mbps. With CAN, the data is present all the time, so the datalogger just listens for what it wants. This means that the update rate for a particular parameter is not impeded by monitoring multiple parameters.
Originally Posted by gernby,Jan 12 2011, 11:32 AM
You wouldn't want that either! The difference in cost between a device that is totally self contained with its own OBDII / CAN interface vs one that gets its data from the FlashPro is probably $1. Actually, I take that back. It's probably much more costly to build a device that would get its data from the FlashPro.
Originally Posted by spectacle,Jan 13 2011, 07:44 PM
I can say with 99% certainty Flashpro datalogging is not done by OBDII. The protocol is way too slow
Originally Posted by spectacle,Jan 13 2011, 07:43 PM
DashHawk doesn't look bad. But there's things in the Hondata datastream that the OBDII protocol will have no clue about like boost control duty cycle & A/F Ratio (AP1) and also the speed of the sample rate. I have a Scangauge II in my daily that operates off of CAN-BUS like you mentioned, and the sample rate is horrifically slow.
