Air fuel ratio suggestions
Hi, building my car now with a carbon ram air intake, j's header, test pipe & j's dual 70.
Will be doing a flashpro shortly so wondering what air fuel ratio to run.
As this car will b tracked heavily & track temps are often 40-50deg C, I want to run an air fuel ratio erring a little on the conservative side. Any suggestions to share?
Originally Posted by steelers743,Feb 11 2011, 07:29 PM
I run around 13.1 a/f corr. No problem with knocks at all from all the data logging I have done.
What are the track temps u normally experience and how many rounds do u go before u pit?
You go with what the car wants; for the most part. N/A Honda's usually like 12.8-13.5. I'd just tune to 13.0 and call it a day unless you have a dyno handy.
The OEM O2 sensor reads a bit richer than it really is, but not as rich as the AF Corr value suggests. I've found that I get max torque with the AF value at 12.5:1. I tune on the street using my soft dyno. If your temp compensations are set correctly, you won't have any issues on the track.
s2000honduras
01-23-2006 10:17 AM
