AEM UEGO Gauge
AEM UEGO Gauge
I Installed a AEM UEGO gauge, not the component to the ecu. The gauge has a white wire that in the directions say can be pinned into the AEM EMS that I have.
Question is can I just take out the old C16 o2 sensor pin and insert this one in it's place
or do I have to splice it into the wire
or do I need to take the pin out and and have both the wires on one pin into the ecu
If your car is already tuned using closedloop with the factory narrow band leave the Pin at C16 and add a deticated pin (depin the existing one, insulate it and add a new one) for the UEGO at C15 for O2#2.
If your car is not using an O2 sensor at C16 already just depin the factory one at that location and insulate it, then add a new deticated pin for the wideband.
spapdx
10-16-2020 09:48 AM
