AEM Cold start problem
Cold start issue
Can someone help me out send the calibration value of the Crank injection time or startup fuel.
I keep cranking - cranking - & cranking and it will not start. But once started (even in seconds) the car will have no problem restarting. Only early morning first start.
The injectors are pushing too much fuel. When I turn the fuel pump off (i have a manual switch), it will start.
There is a value under "startup fuel" or any value you can find under cold start.
Thank you!
Thank you!
Cold start issue
Thank you!
Thank you!
I'm having this issue with my aem v2 Ems . And last time I took car to the tuner to adjust when I got back home turned off car then tryed turning back on. Car will not start at all idk what to do. I'm having all kinda issues with my aem ems
