yellow box install
yellow box install
i know that the yellow box requires a 11% change from stock, however with the tires i have should i change that 11% to something else? my tires are 245/40/17 also if somone has a write-up of the yellow box install with pics that would be great. thanks.
Since you didn't mention it, I assume that you're talking about 4.56 gears (which would be 11.2% by themselves). Those tires you are using would only introduce about a 0.3 mph (or less) difference at about 150 mph. This is not enough to worry about. You will have a bigger error just from the natural OEM speedo error, which has been determined to be anything from dead on to 2%. If you truly want a perfectly accurate speedometer, you'll need to get paced by a known calibrated source like a police car, mileage test markers on the highway, etc. Then you calculate the % error and dial that into the YB.
use the mile markers, method given in the yello box instructions. be done with it.
i didnt think there was that much err (2%) in the oem digital driven system but 2% is very small.
MajorHavoc
08-03-2016 05:45 PM
