Wiring harness question
Old 07-27-2006 | 05:31 PM
solomon's Avatar
Default Wiring harness question
I apologize in advance because this is definately a noob question, but a clear answer would be fantastic. I recently purchased a Pioneer DEH-P680MP HU. I picked-up a wiring harness from Metra, model number 80-1721. The question I have is concerning the wiring harness. The harness has two plugs, one large blue one and one smaller white one. I know that these two plugs connect to the factory harness. These two plugs are joined by wires, meaning that there is no bare wires to connect the Metra harness to the HU harness. So do I splice the wires from the HU into the Metra wiring harness? Am I on the right track here, or am I totally missing it? Thanks so much in advance for any responses.
Old 07-27-2006 | 06:01 PM
JDM S2000's Avatar
Banned
hack the one end off that wont fit on the factory harness.
Connect all colors together on what you have left, that is what I did on Saturday
Old 07-27-2006 | 06:06 PM
solomon's Avatar
Which end didn't fit? The blue or the white? Do i have the correct harness, or is there another that doesn't require hacking one end off?
Old 07-28-2006 | 07:02 AM
Dave-ROR's Avatar
You splice/solder the Metra harness's wires with the HEADUNITS harness. You then plug the Metra harness's PLUGS into the Honda harness plugs.
Old 07-28-2006 | 07:38 AM
oth's Avatar
oth
that harness looks like it's designed to connect a specific headunit to
the factory harness - the generic metra harness that plugs into the
factory harness is the 70-1721.
see http://www.audiooutfitter.com/store/70134/701721.html
Old 07-28-2006 | 08:02 AM
JDM S2000's Avatar
Banned
Yeah its for stereos that come with a harness that plugs in from the factory.
Take your stereo out and see which one fits, then hack the other side off(leave as much wire as possible) then connect colors, I think all i had left was orange/white.
Old 07-28-2006 | 08:57 AM
solomon's Avatar
So, should I cut the harness I have, or just go get the generic one? Thanks again for all the responses, I appreciate them.
Old 07-28-2006 | 09:36 AM
Dave-ROR's Avatar
If you have the harness that is designed to install a OEM honda harness into another car (in other words, the metra harness you have can be plugged into the honda RADIO) then return it for the right one which will allow you to connect an aftermarket radio to the honda HARNESS.
Do NOT cut the factory harness. (you can, but it's a pain dealing with it)
Old 07-28-2006 | 09:56 AM
JDM S2000's Avatar
Banned
Yeah do not cut the factory harness.
Id like to show you what I did with your same situation, but I am not pulling my stereo out for that.
I did not touch the factory harness except to plug it in.
Find a picture of what you have and Ill show you what to cut
dres2k
11-29-2008 02:38 PM
doctornick
05-16-2007 04:30 PM
cleanaudi
03-20-2007 04:00 AM
JohnnyRingo
02-08-2006 03:25 PM
justdrew424
07-13-2003 08:01 AM
Quick Reply: Wiring harness question
