wire harness
trying to get my stuff in order, the basic harness offered through crutchfield will get the job done, correct?
but WHEN(not getting it right away) i get the DCI from modifry i will need to get the harness they offer ??? or can i get the modifry harness right off the bat??
looks like i cant just start with the modifry harness because it says
"you must buy the Alpine IR or Alpine Wired DCI for this harness to work"
that is for the plug n play harness.
you could get the non-plug&play harness from Modifry and splice it
to your Alpine, as you would with the Crutchfield harness. Then you'd
be ready to add the DCI without purchasing a new harness. The problem
with many generic adapter harnesses is that they lack the s2000-specific
dash switch and mute switch wires, though I don't know if this is a problem
with Crutchfield's.
with Crutchfield's.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
If, however, your head unit is from another company then you need to get the non-PnP harness, of course.
