Where should I ground my head unit?
Old 01-31-2009 | 12:43 PM
dparm's Avatar
Default Where should I ground my head unit?
I can't find a spot for my head unit ground. No good bolts nearby. Tried running the ground under the center console leather to the hand brake area, but it's too snug and I can't push the wire through.
Old 01-31-2009 | 01:54 PM
Eric220's Avatar
I used the bolts that were used to remove the stock head unit. Works good for me.
Old 01-31-2009 | 02:00 PM
dparm's Avatar
You're saying the two bolts that the brackets use to hold the head unit in place?
Old 01-31-2009 | 02:44 PM
dparm's Avatar
Ended up using the bolt inbetween the two screws on each side (for the bracket). Seems to be fine.
Old 02-01-2009 | 07:04 AM
hariku821's Avatar
I had my HU installed by circutcity. The only wires on my hu connect to the wiring harness.
Do i need to hook something else up or am i fine?
sorry for the thread hijack
Old 02-01-2009 | 09:31 AM
Penforhire's Avatar
One of the install FAQ's here shows a brass colored bolt near the HU face and that worked fine for me.
Old 02-01-2009 | 11:00 AM
Neutered Sputniks's Avatar
What HU did you have installed?
Old 02-01-2009 | 01:20 PM
dparm's Avatar
Yeah I think I've "double grounded". The Pioneer & factory harnesses had black "GROUND" wires that I connected together. But the Pioneer also had a grounding clip that you attach to a bolt. My guess is they do it just to be safe. in case one fails.
Old 02-01-2009 | 07:35 PM
hariku821's Avatar
pioneer DEH-p3000ib
Old 02-02-2009 | 09:07 AM
Eric220's Avatar
That works Just make sure everything works and theres no static.
