Where to route wires for A-Pillar Gauges?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
I just got a single a-pillar pod for my AEM UEGO gauge. However, I'm having trouble figuring out how to get the wires to route from the engine directly to the a-pillar. Is there a hole somewhere under the windshield wiper trim or something?
I did a search but couldnt' find anything helpful
![frown.gif](https://www.s2ki.com/forums/images/smilies/frown.gif)
I just did this the other day. Here's how I did mine...by the clutch, you will see a rubber grommet w/wire bundle coming out of it. The other side of that wire bundle leads to the far right(driver's side) of the engine bay....really can't miss it, just shake the wires around to confirm it. First,I connect the bosch sensor then route wire through engine to my liking. Next, I poked a hole through the said grommet and just shoved the white connectors in until I can go inside the car and grab it through the grommet w/pliers. Then I routed it up pass all the wires, ecu, etc. and up into the dash and into the small opening by the window and a pillar. Grab it from there and pull the wire and connect to gauge. Remove the fuse panel where your hood latch lever is for easier access. That's the way I did it, lmk if you need pics...gl
Ok thanks. I knew about that grommet already as I just wired up my Nitrous system through there. I wasn't aware that there was an outlet to the A-pillar through the underside of the dash though...thanks!
