What Amp should I get with my aftermarket speakers?
So I bought new speakers last year and they sound great, but after I start to crank up the volume with the top down the bass starts to get distorted.. In this case what should I do? I have an Alpine cde-121 now but may be looking into another upgrade for a deck.. So my main question is, how do I get a clear sound when the volume is up pretty high? Obviously an amp, but which one is good for what I have and won't blow up my speakers?
Or should I go with this thing?
http://www.bestbuy.com/site/Alpine+-...&skuId=9442187
Speakers:
http://www.bestbuy.com/site/Kicker+-+KS+6%22+2-Way+Car+Speakers+with+Polypropylene+Cones+(Pair)/1671393.p?id=1218277759264&skuId=1671393#BVRRWidge tID
Speakers:
If your speakers are distorting at higher volumes, amplifying them won't make it better. The speaker link ^ is no good, but I'd recommend you upgrading your stock speakers before amplifying. I would look into a good set of component speakers if you want sound quality.
The usual cause of distortion is turning the volume up beyond what the
amplifier (internal to the headunit in this case) can deliver, so you
are likely right that adding an external amplifier will help.
That Alpine KTP-445 amp is popular and easy to install, but may not
be powerful enough depending on how loud you are trying to go.
That said, it could be worth trying due to the low cost and easy
installation.
Otherwise, there are truly an infinite number of amps that will work -
some things to think about are:
- do you want to to be hidden (if so, physically small is good)
- do you think you might add a subwoofer (a four-channel amp could
potentially power your door speakers and the sub)
You're unlikely to blow up your speakers no matter what amp you choose.
installation.
Installing a larger traditional amp will also solve your problem, and allow for more options in the future (subwoofer, rear speakers, etc.). But that is always going to be more expensive and more labor intensive.
"A good set of component speakers" will still sound like $hit if they're not amplified.
EDIT: 1500 posts, hooray....
No, it doesn't really work like that. Now you could add some speakers behind the seat and utilize the other 2 pair of speaker outputs.
I would start with getting a better speaker if you want a cleaner sound and more volume. Hertz/Audison is a favorite of mine. I would look at their energy line and their sr4 4 channel amp.
