Vibrating Panel
Vibrating Panel
I installed a Rockford Fosgate T400-4 with Polk MOMO10" subwoofer in custom enclosure, etc. It sounds absolutely amazing except there's a panel that's vibrating when the subwoofer is at certain frequencies.
The panel is the one behind the seats just below where the roof connects to something - it's the rear panel of the area where the roof folds down into. The problem is that I can't figure out how to get the panel off and I don't want to risk cracking/breaking something as it seems like the panel is made of hard, almost brittle plastic. How do I get the panel off to add some soft insulation so it stops vibrating?
Any help will be appreciated. Thanks.
there are a lot of little .... tabs i guess? you have to depress the middle, and then you can pull out the whole "tab"... do that all the way around and then you can remove the soft-top "tray"
imagine
06-02-2007 07:55 AM
