uninstall VAFC II
I've done about a dozen install/uninstalls.. Most of the wires except for 2 are directly spliced in.. There are 2 that are totally cut.. the VTEC signal wire, and i believe the second is the pressure signal wire(pink/purple on the VAFC harness).. you will need to re-attatch the wires together after you remove the wires on each of them. If you are clueless on how to do this, its better to pay someone because you do NOT want to mess up your ECU. Post up if you have anymore questions.
nownor
04-10-2003 05:35 PM
