turning the factory alarm off
ok. i searched and found the install manual. still i have a question. can i just pull out the 2 relays? do i have to pull the entire system out? is there a fuse i could pull out? didn't know if the valet switch is usable but i haven't seen it on the car itself.
it's a 2000 s2k.
thanks ahead.
mike.
oh here's the manual: http://www.handaaccessories.com/s2000/s2ksecurity.pdf
it's a 2000 s2k.
thanks ahead.
mike.
if your installing a new clifford alarm there is a factory alarm disarm wire that your clifford will connect to. no need to remove the whole factory unit.
It is a white wire at your keyless entry module. PM if you need help.
