Subwoofer Amp 1000+ watts *ALSO great deals inside*
Old 04-27-2004, 08:15 AM
OC S2K's Avatar
Found some great deals.
I'm going to get a nice Audison amp for my components so I thought I should budget myself on a subwoofer amp.
What do you think about these:
Soundstream EGA 1400D Edge Series EGA1400D
1400x1 @ 1ohm
$329.99
http://www.sonicelectronix.com/viewitem.php?id=1695
Mark Antony MK-1500X MK1500X (I haven't heard too much about these).
1500x1 @ 1ohm
$349.99
http://www.sonicelectronix.com/viewitem.php?id=1498
Phoenix Gold Tantrum 1200.1
1200x1 @ 2ohm
$329.99
http://www.sonicelectronix.com/viewitem.php?id=738
Old 04-27-2004, 09:04 AM
PJK3's Avatar
well, one question first... what sub are you planning on using? the PG Tantrum makes it's power at 2 ohms, but the other two need you to be down at 1 ohm. the sub you choose will affect which amp you should buy. if the sub isn't a 1 ohm or a 2 ohm DVC, then neither the Soundstream or the MA (don't know anything about it) will work for you. if you've got a 2 ohm SVC or a 4 ohm DVC - the PG Tantrum is your only option to get over a kilowatt.
Old 04-27-2004, 09:07 AM
NFRs2000NYC's Avatar
Dimming Dimming Here we go,
How to fix you I dont know!!!
Find a sub you like, then worry about amps.
Also, can I sell you some duct tape and zip ties???
Why? youll need it to put your car back together after it rattles apart.
Old 04-27-2004, 01:39 PM
OC S2K's Avatar
Tried to edit, but the site was down at that time.
12" IDMAX
Old 04-27-2004, 01:51 PM
Ehhhh....eclipse Ti's are much better made/performing subwoofers.
As for amps.....some great sub amps...
Tarantula 880.2, 1600.2, 700.2
Old 04-28-2004, 03:29 PM
OC S2K's Avatar
Those amps I believe are out of the budget I want to spend. If I wanted to spend a couple hundred more, I'd go Audison or something. What do you think about those amps above?
Old 04-28-2004, 08:51 PM
As much as I LOVE audison amps...they arent the greatest amps for subwoofers. I like Tarantulas the best for subs. You can have the tarantulas for mid 300's You arent going to get a real 1000watt amp for less than that. (the audisons I am talking about are the two lower lines....the top of the line just isnt worth the money for subwoofers....its over 1200 bucks!)
Old 04-29-2004, 05:53 AM
PJK3's Avatar
so, which sub did you finally decide upon. honestly - it's hard to recommend an amp until i know what impedence load you're planning to use for your sub.
Old 04-29-2004, 08:37 AM
[QUOTE]Originally posted by PJK3
Old 04-29-2004, 11:18 AM
OC S2K's Avatar
Quick Reply: Subwoofer Amp 1000+ watts *ALSO great deals inside*
