Stupid amp question
Stupid amp question
I purchased some polk db6500's( better than average speakers) and running it off an Alpine HU.
I'm running the speakers directly from the HU and at around mid volume the sound is distorted and saturated. I tried messing around with the EQ, and I still get crappy sound. My OEM speakers sounded better.
1.Do you think driving the componet speakers with the HU is the culprit?
2. Will an amp greatly improve the punch?
3. Are these speakers just crap( I purchased them because they were easy drop ins)..... ( no flamin please)
I feel the install was clean. All the wires were soldered.
4. I'm not sure, but is it possible that compression may be caused by having the +/- polarites reversed on the speaker connections .....just a possiblity, but I think I wired it correctly.
Thanks guys....
I will try the unscientific approach to see if I have a phasing problem..
BTW: last night I read the Alpine manual and figured out how to properly use the EQ. I now get a wider bass response, and the speakers do sound a lot better. I still feel in order to fill the low range void, I will need a sub.
