Stock HU + Amp + Kappa Speakers + Bose Sub
#23
Using the sub without an external crossover just sounds horrible. I used to have this hooked up to my OEM HU with speaker level inputs and took it out b/c I hated the sounds it produced.
Using the Alpine HU, in combination with using the +15 dB subwoofer level, I had to turn down the level for my front and rear speakers using the crossover to set them to -12 dB.
Also, I used to have my stock HU hooked up to a pretty good PPI amp and some good MB Quart components. I replaced the stock HU with the Alpine to take use of the built in Xover and MP3 playback, but I can't really tell much of a difference in sound quality, between the RCA pre-outs off my Alpine and the stock line level inputs. If you get a decent line level converter and install it right, using the OEM hu is fine and can sound really good with the right amp.
#25
as if you havent wasted more than enough hours telling the same people the same thing over and over again
please
i have no plans to amp the highs because the sound is more than enough, and yes between the rear speakers and the stock components i dont believe you need a new deck at the cost of having to add a dci to keep stock controls
MY point is an upgrade above a stock deck is unnecessary for most of the people that get recommended them
now piss off for questioning that i dont know what i am talking about full range, i dont have tweeters blasting in my ears and i dont care to
no offense of course
please
#26
please
please
what is a waste of my time is reading and being stupidly goaded into responding to this tripe, and in being verbally assaulted for trying to help someone get better sound in their car. and if you haven't noticed previously, i simply make recommendations, usually giving people multiple options and choices -- i don't force ANYONE to buy or do anything. in fact, i always encourage people to go listen for themselves...
on the other hand, i don't see you doing much but stirring up issues.
still in the end, there is a simple solution for me.
#30
AudioFreak, you are outta line here. PJK3 has gone WWAAAYY out of his way to help many many people in dire situations.
He knows what he is talking about. His consistent recommendations are no reason to slight him. Alpines, Focals and Elemental designs are all good gear. His consistency should be applauded because he does not fall for every new gadget available. He knows what he likes, and recommends that. Always, ALWAYS, he points out that it is up to the listener to choose ultimately what they want. Yes, there are many choices, as there are levels of audio freakiness. Some people swear by gear that I deem crappy, and vice versa. When it comes to music ears are like taste buds, some people like their food spicy, others like it mild...
Your system sounded good given that you only added a sub and rears. BUT, by no means was your system comparable to a properly tuned amped system with quality gear. But for the money, it was a good compromise. I could not listen to your system everyday and be happy, but I understand that it is a system on a budget, and you did well with what your budget allows. Still, the lows were muddy (we talked about this), and the mids and highs were far from true. However, you spent what, $400?! So for $400, sure it's an improvement, but by no means is it perfect or at all close.
I do have to agree that the 'o4 headunit is much better that 00-03's. But I am still replacing mine. I would recommend replacing it to anyone who is concerned enough about sound quality to ask. If you aren't asking, I'm not going to recommend.
But if someone asks for an improvement on a budget, adding rears and an amped sub might be enough, but it wouldn't be for me.
Instead of attacking someone who has helped out countless enthusiasts, maybe you should suggest your recommendations to the noobies. You would have much more influence that way and you would make less enemies.
you seemed like such a nice guy , too. Weird you would get so emotional about speaker choices....
