Stock Deck 4-Channel Power?
I see a hook up in the harness for front & rear speakers yet there are only door speakers with seperate tweeters (are these the rear channel)?
I am installing a Sony head unit with the wired dci adaptor and I just want to make sure of my speaker hook ups. I thought the front seperates were all run off one channel.
Magnus
Having looked at the wiring diagram for OEM cars with stock tweeters, those tweeters are spliced into the main door speaker circuit and have nothing to do with the empty, unused "rear" channels. Using those rear channels for another set of speakers will effectively double the wattage output to the stock sound system.
Thanks guys!!
So where do the rear speaker leads go? Is there wiring termination that goes to the rear deck? I would love to add another pair of speakers in a factory location if there is one.
Originally Posted by F1fletcher,Mar 21 2006, 09:34 AM
Thanks guys!!
http://www.collegehillshonda.com/instructi...estspeakers.pdf
There are other options for adding speakers as well.
Check out the following links for more ideas:
http://www.streetsmarttechnologies.net/
http://lucidauto.com/Merchant2/merchant.mv...egory_Code=RSS1
Magnus
EMarkDDS
02-17-2003 06:29 PM
