Stereo shorting out/turning on/off
Old 09-04-2007 | 12:13 AM
a_zepeda926's Avatar
Default Stereo shorting out/turning on/off
I was wondering if anyone had the similar problem as me and could provide me with the fix... I have an 05 with the stock headunit in and every so often the stereo turns off and comes back on a second or two later and will continue the cd from where it stopped. at first it only happend once in a blue moon, but it seems to be happening more and more, almost everytime i drive it. thanks for your input!
Old 09-04-2007 | 08:06 AM
neoarroyo's Avatar
do you have an amp? Sounds like the amp might be going into protect mode. I had a similar issue and fixed it by modding a fan to cool the amp.
Old 09-04-2007 | 08:38 AM
negcamber's Avatar
Mine has been doing this too
Old 09-04-2007 | 08:49 AM
Eddie J's Avatar
same thing happened to me...only it occurred when going over rough pavement. the source of the problem was a loose ground. the bolt holding the ground wire/ring terminal had come loose. mind you, this was for an aftermarket system, but i'm sure the stock system has a ground as well (i *think* it's near the HU...).
Old 09-04-2007 | 09:08 AM
SheDrivesIt's Avatar
Take it to the dealer and have them fix it under warranty. Are you under 36K miles?
Old 09-04-2007 | 04:57 PM
yea im under the mileage and the year limit, and it is stock keep in mind. i would much rather fix it myself if it is something as silly as a loose ground. i hate having other people work on my car.. im just that kind of person haha, but if i have to i will. anyone have any idea where the ground may be? and is this the common behavior of a loose ground?
helothere
09-22-2014 03:33 PM
cen_14
06-09-2008 08:46 PM
bwalk22
04-13-2005 03:20 PM
JawKnee
03-07-2005 04:03 PM
overkill
04-24-2004 05:49 PM
Quick Reply: Stereo shorting out/turning on/off
