Speakers, amp and HU
Originally Posted by bakalag,Oct 9 2009, 02:22 PM
oh I figured out what was wrong, there was a setting called HFE or something...HPE? but I turned it off and sound isn't bad sounding anymore and bass kicks in now.
Thanks for the help!
Originally Posted by bakalag,Oct 16 2009, 03:56 PM
I took the car to the dealer to get it checked for something today and a tech asked to check my battery. He said it is due to replacement 454 CCA/625 CCA. I asked if it has to do with the amp in the back, and he told me the amp is probably drawing the power from the battery cause I don't have some sort of filter system for the amp. What filter thing is he talking about, and should disconnect my amp since it may be draining my battery?
Is your amp turning off when the car is off? It should be. And how much power does it produce in watts RMS, or what is the make and model of the amp? Some drain a fair bit of power, but you should be fine.
Assuming it is and your car doesn't have any trouble starting, I wouldn't bother with any it for now. The battery will die sometime down the road, just like everything else.
I'm not sure the power in watts RMS, but the make is Infinity. I'll check the model when I get the chance. I think it does turn off when the car is off. I guess I don't have to worry about it now =). Thanks for the response.
