S2000 audio/video systems
#633
Originally Posted by R3DS2K,May 14 2010, 05:33 PM
thanks. what would you like to see ?
wider angle of the trunk would be appreciated too.
How long did it take start to finish?
#634
Originally Posted by riztech,May 14 2010, 06:27 PM
The tweeter install, cross over and door speaker install.
#635
Originally Posted by R3DS2K,May 14 2010, 08:24 PM
i work everyday so i spend like two days on it after work. if had to do it all over again it should only take me 4-8 hours. i get anal on how somethings need to be done thats why. ill have to check my pictures i took and see if i can find any of the ones you want
#636
how much does a whole set up cost like the ones in the beginning of the post? and then how much does it cost to install it all? Thanks, i really dont like how the stock sounds
#638
this is not so pretty but it works. just used left over scraps for the supports and custom mount
#640
Originally Posted by BumbleBee01,May 21 2010, 08:17 AM
How much does a whole system cost? I have a head unit and an amp already
For starters, you could budget $300-400 for a decent/nice 4 channel amp for speakers and $300-600 for speakers, then $75-$150 for RCAs and additional wiring. Then $200-800 for the subwoofer, enclosure, and associated stuff, but use the amp you have if it's appropriate for the system or buy a new one for another $200-500. That would produce sound that is loud and clean--overall very good by most standards--but it wouldn't win any competitions or blow an audiophile away.
So a grand or two is my answer.
Or you could halve some of those cost numbers and take the minimums on others and get a lower end system, ie maybe a system with plenty of volume but poor equalization. Or you could double some of those numbers (or more) and get a very high end system with more volume than you can stand and clarity that stirs the soul. Personally, if I were doing that, I would want to put the nicer system in a different, non-tinny-uninsulated-ragtop car, as the finer points of such a system would be hard to enjoy in this car. YMMV.
