S2000 audio/video systems
Old 07-20-2009, 12:52 PM
  #591
Neutered Sputniks's Avatar
Claus, I highly recommend Sundown amps. Pick up a 50x4 (probably closer to a 60x4) for $350 or so. Excellent SQ (the guy who designed them is an SQ fanatic) and you can't beat the price. I'm actually using 2 of them in my truck (one for each door). Besides running a second set of speaker wire to each door, should be pretty easy to swap it in (and it can run active on it's own)
I chose the Revs b/c I couldn't find anything as high in SQ (without spending MUCH much more on car audio specific speakers from an authorized dealer - I don't buy gray market anymore, just not worth it) that would fit in the doors with a 4ohm impedance. Unfortunately, short of upgrading my amp, this was pretty much a required impedance level. I'm certain it will be worth the effort when it's all done
Old 07-21-2009, 08:30 PM
  #592
Claus's Avatar
^already have two sets of wires running into the doors, copper for mid bass and silver for tweets and.... I know I'll end up buying another pair of $200 RCA's if I go active...
stop making me pull out my sexy RS6 xovers and VRx out of my trunk
Old 07-21-2009, 09:41 PM
  #593
Yo...let me know when you're ready to switch to active. I'll build you custom RCAs (like I did for my truck), cut to whatever length you specify with soldered plugs (and you can give me the $200)
I think I spent maybe a total of $150 on 3 sets of custom length RCAs (Belden coax, solder plugs - 15', 17', 21')
Old 07-21-2009, 10:28 PM
  #594
Claus's Avatar
will do, but can you give me a deeeeep discount and throw in WBT plugs for free
would love to compare the difference between them and my nordost blue heaven if i do switch
Old 07-21-2009, 10:51 PM
  #595
WBT plugs start at $50ea...
I use the Dayton gold plugs, $5-7ea and, lets face it...it's not like there's really that much difference between WBT and Dayton plugs...they're gold, they're solder, they're RCA plugs...
Old 07-21-2009, 11:18 PM
  #596
Claus's Avatar
the problem with me is that.... I treat cables like jewelries for my sound systems And Germans are too good at machining, hehe~ j/k
And you've done it... I'm not gonna go active as yet but might start a RCA shopping spree soon, in hope to find something as detailed and as fast as blue heaven while being warmer and having a wider soundstage....
the RS6 and blue heaven combo sounds good, but is too agressive for some recording atm... However, the bh would be perfect with Seas though, ahaha
you might get a pm within a week or two RCA review inc?
Old 07-25-2009, 09:39 PM
  #597
Claus's Avatar
might go active if the Germans are willing to sponsor and make me remove my Italian power house
still talks and not for sure atm though
Old 07-30-2009, 03:50 AM
  #598
Claus's Avatar
update: fixed overly agressive staging by deadening the platic door panels more(only had closed cell foam before, now has mat and foam), which reduces rattles and harmonics
driver side sound stage now extends up to two feet beyond the door
Old 07-31-2009, 07:18 PM
  #599
Deusirae's Avatar
Here is my system. It is made up of an Alpine 9886 head unit with wired Modifry DCI and Alpine KCE350BT blue tooth interface with streaming audio and Sirius radio.
Speakers include Pioneer Premier 12
Old 08-13-2009, 07:57 AM
  #600
dierk's Avatar
Originally Posted by lovegroova,Jun 14 2009, 02:31 AM
Imprint is in use and makes a very positive difference, although it's negated by having both roof and windows down. The windows make more difference to sound quality than the roof position though (unsurprisingly).
Can the Imprint remember different settings? I'm looking forward to installing an equalizer. I'm hoping to be able to call up a different profile depending on acoustic environment (soft top up, soft top down, hard top on, windows open, windows closed, etc...)
Quick Reply: S2000 audio/video systems
