Running an amp to door speakers
ok so i just bought a new aftermarket head unit for my honda s2k. i want to buy some aftermarket speakers i was looking at the Polk Audio DB6501 6.5-Inch 2-Way Component System or the Kicker 40CSS654 speakers. but i want to run a small sub to the speakers. now my question is how can i wire the amp to the speakers and keep it looking stock as possible. I will be saving the stock stereo and speakers so i can change it back to stock if i ever do decide to sell the car. Is there anyway i can run the amp directly to the head unit and what would i need to be able to do that? i just wanted to buy an wiring kit so i wouldn't have to cut any if the stock wires. and i also want to mount the am inside the car i was just looking at a small amp like this http://www.ebay.com/itm/like/331116627069?lpid=82 could i fit that under or behind the passages seat? thanks so much for the help. I don't want to go all out and i defiantly do not want a sub. i want some nice speakers with an amp to get some some nice clean sound
The Polks you showed are 4 ohms, 100 watts RMS each while the amp shown is only 4 ohms 30 watts per channel. You might want to find an amp with a little more power rating to get the full effect from it. As for mounting location, I have a monoblock Alpine amp for my sub mounted behind the passenger seat and it's a really tight squeeze but I haven't had any problems so far.
