Roady 2 headunit...where did you put it?
Where did you mount the actual head unit of your XM radio? There are plenty of surfaces to choose from, but I want something that will be relatively clean in case I ever decide to get rid of the radio.
Thanks,
JNT Handyman
Thanks,
JNT Handyman
I have a roady1, but it's essentially the same.
You know the bracket that goes on back? I trimmed the bottom a little to make it easier to remove from the unit. I stuck that bracket to the radio door with some tape and it works well. the door opens enough to pull CDs, too. I also used a wired FM modulator which comes with a 6VDC out, meaining you don't need the lighter socket. Everything is behind the dash with the 3 wires coming out under the door.
