Red/White wire
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
I recently installed and Asteroid Smart in my S. After a very short period of time it developed a fault and I had to send it back. On return I bench tested and it works fine. I install and no luck.
It appears the issue is no power on the red/white lead ins the standard loom. I assume this is the ACC lead and should be 12V when the ACC is on. Unfortunately not. I have checked the ACC fuse and it is fine. Where else does this wire go and how does it connect to the fuse box?
Any help would be appreciated.
