ok i guess i need a sub - how do i wire it on the factory head unit
just don't know how we can wire it up
Factory head unit to a LLC - four RCAs running to the back with two amps (one big one bridged feeding the frt Diamond hexs and small one bridged feeding Diamond S-pods)
how do i get a sinal to a sub?? when i don't have a sub out on the factory head unit??
i assume i'll lose my fader option or something
Thanks
Thanks
Uhhh,
Don't your amps have a signal out? To pass that signal on to another amp? That's what you need to do. If not, you really only need to split a signal off the existing RCA's with a Y-Cable and run that to the sub amp.
I understand that each amp is independent. But the question is do they have an RCA Out on them? Of so, then just run cables from the RCA out to your sub amp. If they don't have this, then split the RCA Cable pairs with a Y-Cable, and run a set of leads to the sub amp. Should be easy and cheap.
