No Door Courtesy Lights on S2000?
Old 01-10-2012, 08:28 AM
  #41
TPhong's Avatar
DEI 611T is the timed relay that I used. This will work to keep them on for the 30-60 seconds after the car is turned off. You will have to wire power from the ignition/accessory if you want them on when the car is on. With another relay, you may be able to trigger the timed relay to continue keeping the LED on, but you'd definitely have to diode isolate to prevent feedback.
Old 01-11-2012, 03:06 AM
  #42
AutoUnionAG's Avatar
I used something similar to this from advanced auto to light the footing area.. Two 2.5 watt bulbs are plenty to light it up if anyone wants to do the same. I have mine wired to my headlights.
http://www.oznium.com/led-ribbon/photos
Cheers!
Old 03-07-2012, 06:27 AM
  #43
BooGTS's Avatar
What two wires for the power windows are always active? I quick multimeter test would confirm this, but for anyone who doesn't have one handy...
Old 09-08-2012, 09:05 PM
  #44
Hoang's Avatar
2012, still no DIY?
Old 09-09-2012, 09:56 AM
  #45
darkknight1999's Avatar
These should be wired to the overhead lights for it to work properly. You can also jump on the door latch circuit. Only takes about 2 hours to install these. Its very easy to do. I did this to my car back in 2003. I was in the doors anyway so I just added them in. Its very simple to do.
Old 09-10-2012, 04:09 PM
  #46
gregor_konstantin's Avatar
im not too familiar with electronics myself and would like some guidance as to whether you only need to wire in LED's, along with what route to take to wire it to the dome lights.
love to see some additional info if anyone could share.
Old 03-28-2013, 05:53 AM
  #47
axus19's Avatar
What if you wire it to the door switches for power? I might look into it on my free time
petawabit
04-30-2015 11:38 AM
SilversS2000
05-04-2010 04:37 AM
txst
08-10-2001 09:58 AM
lucid
06-25-2001 03:34 AM
Quick Reply: No Door Courtesy Lights on S2000?
