Need help with new Alpine HU install for 99 TL
My bro has a 99 Acura TL. He bought a Alpine CDA-9886 HU yesterday. The install went smooth, but when we tested the speakers, the stock Bose subwoofer was not working. Is there a wire in the harness that specifically works with the subwoofer that goes into the HU? Any help would be appreciated.
Thanks
Thanks
on the back of the HU there are rca outputs but the factory HU harness does not have inputs. I'm guessing the subwoofer wire is in the harness but I dont see... does anyone know what color it is? Also, will the factory subwoofer work with this alpine HU?
or could it be a fuse that is bad?
thanks
thanks
Originally Posted by SheDrivesIt,Aug 5 2008, 10:45 AM
I would say you are going to have to drive it with an amp. That may be tough as the Bose sub is probably very low impedance.
If I were your brother I would pick up a replacement sub and amp and just install them in place of the Bose. Chances are he'll be happier with the sound anyway.
Actually ur all taking the hard way out.. You can integrate the subwoofer.. we always give the option to our customers to integrate or rewire.
You just have to find the subwoofers amp turn on wire, and find if the signal going to the sub is low level or high level...
You can integrate any boss, jbl, monsoon, or any factory system if you have patients and actually test wires.
Done it many times.. not on a tl yet but its all the same when it boils down to it, just differ wire colors.
