Multiple failures
Multiple failures
Recently I had several failures which all seem to be associated with the door switch. Upon opening the door the headlights on chime, keys in ignition chime and the interior lights stopped working. I am sure 2 of the 3 are only connected to the drivers door however the lights don't come on when the passenger doors are open either. I have looked for a fuse that may be linked to the door switch but can't find one. Does anyone have some suggestions to fix my 2003?
Probably just the connection in the lights worked itself loose. Pretty common at one point in time. I believe (but could be wrong) the cover pops off and you can fix the connection.
Errr...you're saying all 3 of them don't? I would check the back of the switch to make sure all the connections there are still good... Generally, all the controls on the passenger side actually run through the driver side door...
