modrify Sony-DCI and CDX-M850MP ?
Old 12-15-2003 | 07:23 AM
mcomer's Avatar
Default modrify Sony-DCI and CDX-M850MP ?
I just upgraded my HU to the CDX-M850MP and am having some problems with the Sony DCI I ordered from lucid. Basically, the dash controls work, but they do not perform the functions they are supposed to. Volume up makes the volume go down, volume down changes the mode, weird stuff like that. The mute button works perfectly, but the rest of the dash controls do not work as expected.
Again, this is the hard-wired Sony specific DCI, not the IR version.
Anyone have any thoughts on what might be wrong before I get in touch with the folks at Lucid?
Matt
Old 12-15-2003 | 01:41 PM
mcomer's Avatar
Anyone? Beuler?
Old 12-15-2003 | 03:03 PM
modifry's Avatar
OOOPS! Sounds like you may have a bad one.
Do you have the SCV (speed-controlled volume) connected? If you do, and it adjusts volume up and down correctly, then you definitely have a bad DCI.
If you don't have SCV connected or it does not work right, verify the plug is inserted all the way into the back of the head unit. That's the only other thing I can think of (besides a bad DCI) that may cause erratic operation.
Lucid will definitely send you a replacement, but he may be low on stock right now, which is because I sometimes can't make 'em fast enough.
Old 12-15-2003 | 06:29 PM
mcomer's Avatar
SCV is not connected. I will verify that the plug and all other connections are secure. If that does not help, I will get in touch with Lucid.
Thanks!
[QUOTE]Originally posted by modifry
OOOPS!
Old 12-16-2003 | 06:17 AM
ruexp67's Avatar
I have the same HU and DCI. Works fine for me, so it WILL work if the DCI is good.
Old 12-16-2003 | 07:35 AM
pipeline's Avatar
I just received the 2.6 version of the DCI in the mail yesterday, and plan on installing it tonight. I installed the M850MP last week, and ordered the DCI on ruexp67's advice. Installation of the HU was a snap. It took about 15 minutes. Thanks ruexp67.
Old 12-17-2003 | 06:16 AM
ruexp67's Avatar
np. Glad you liek it.
TheHump
11-16-2012 07:06 AM
CatDada
12-24-2006 06:13 PM
joes2
11-28-2004 11:05 AM
albtrssp
10-20-2003 01:54 PM
Woodson
05-27-2002 01:46 AM
