Lucid's rear speaker install
Since theres many brands/models out there I usually research each persons request on a model I haven't built before.
The basic size that fits are 4" speakers with magnet dia. under 3 1/8". Other varibles to consider is if the unit is stock, aftermarket or being amped.
Yes I can get a pair of pioneers to fit...
lucid,
I plan on using the stock radio (as you mentioned in previous posts and on your website, this is possible since there are rear outputs from the deck...), but would like two-way speakers for the rear.
Any recommendations?
also, then you say there is a 3 1/8" limitation on diameter of magnet. what about magnet depth (thickness of the magnet when speaker is viewed from the side)?
