lcd help
lcd help
ok i am planning on getting lcd. but this one has safety feature like if you don't have your e brake (emergency brake, hand brake, parking brake what ever it is called) on the lcd will not pop out. so i heard that i can ground the e brake wire then it will work. but where is this wire located and which one is it?
nah i am not doing the install. because that i got rsx type s and got that bose system. you gotta wire it differently since i got that stupid system.
or you can... the wires on my kenwood lcd are yellow for positive black for negative green for ground. the positive most likely has the inline fuse connected to it. take the negative wire and connect it with the ground wire and then run the negative to the appropriate place.
