just got amp installed, now buzzing sound
#22
After testing the amp this weekend I think that the buzzing sound actually does change with RPM. Is this still a ground loop problem? Where should the amp be grounded?
Thanks to all who pointed out that the installer was bogus. I plan on getting the buzzing sound fixed and then get a sub elsewhere.
I'm still using the original receiver (with Hi-Los to interface with the amp) so I don't have an amp relay wire. I'll connect the amp auto turn on wire to the acc terminal if that's a better thing to do.
Thanks.
Thanks.
#24
[QUOTE]Originally posted by virtualtom
[B]The amp is connected to the number 10 fuse (SRS). There is a slight buzzing/tapping sound that comes through the speakers at all times, even when the radio/CD is off.
