just bought custom box.
Hey-
I just bought a MDF box for a 10" sub. It is sealed now. It is 1.2CF of volume. Can I port this box? If so, what should the port diameter / length be? I have a Clarion SW10x sub. The specs are :
Rec. Sealed Box Dims: 0.70 cu.ft.
Rec. Ported Box Dims: 2.20 cu.ft.
Free Air Usage: not recommended
Sensitivity: 81 dB
Frequency Response: 35-500 Hz
Recommended RMS Power: 300W
Peak Power Handling: 600W
Impedance: 4 ohms subwoofer wiring options
I know the size is not what the specs say for porting, but they may be counting on a larger port. The box is oversized for the sealed box spec. Will the oversizing hurt / help the sub? What should I do with this size box to make it the most efficient.
thanks
John
Sensitivity: 81 dB
thanks
John
Is this box for the tool well? If so, 1.2CF with an MDF box does not sound right (unless it's not flush?), it's probably around 0.8-0.9 which is a good match for your sub.
I would not hack the box.
I emailed the guy who maid it. He said 1.2 cubes. The photos showed in mounting flush. Dunno how he did it, but he did. I think he made it outta 1/2 or 1/4 stuff then re-inforced the walls for form to the well (fits tight). I will measure it when it comes in. If it IS 1.2CF, can I port it? With a small port?
I am used to a bandpass setup and going from that to a sealed enclosure (I have been told) there is a big difference....and it is REALLY hard and expensive to get a bandpass configuration for our cars.
Jogn
Jogn
So I took the time to model up the sub on winisd with the t/s parameters listed on the Clarion site. The driver has a very high QTC and it'll probably play really peaky in that box right around 50hz. If you put in a port with a tuning frequency of 33hz, you're looking at a real long port 2x12" port. It's not gonna sound good at all but probably be really noisy.
thanks guys. I will not hack the box. I guess I will have to see how loud it is like it is first. Is 283WRMS to a 10" sub enough to hear? I am not looking for thumping power, just a fuller sound.
John
John
i am a believer in overpowering, i don't think 283 is overpowering. but if that's waht you've got then try it. if you don't like it, add more power.
