John or Dave... log in fools!
Either one of you fools know anything about the dash lights? Might have to find Billman if not. Let me know, I need to change them.... going for a dragon run Sat. WOOT!
Are you stalking me Matt... WTH? lol
Its the light that lights up the AC/AC return/and fan speed knob. The green LEDs of the fan speed knob are fine.
Haven't taken apart the S, but there may be some small bulbs in little twist in bulb sockets, that's how every other car I've taken apart has done that type of switches/controls.
you can pick up a replacement bulb at AutoZone. I cannot remember the size off the top of my head.... I believe you just need to remove the bezel that surrounds the cluster set (audio, speedo, and AC controls), then just pop the AC control unit out from the back. The bulbs pop out similar to the turn signal lights, if I can remember correctly (rotate the locking housing from the back of the unit).
If this is incorrect, someone please point it out, as I have not done this in a WHILE (will be doing it again when I get my parts back from John, as I have the exact same light out).
Thanks
John
Thanks
John
DJ Qube had a great diy for pulling the dash apart, with pics and everything for his module - its not for lightbulb replacement per se, but it is what you need to do. Alas, the link no longer works -
http://forums.s2ki.com/forums/showthread.p...threadid=138737
Maybe a Mod can find it - I think the link broke when the site revamp was attempted and the main page went away...
Maybe pm DJ Qube?
Maybe pm DJ Qube?
