installing double din ? dash cutters help
i have the jdm bezel, and i have read threw and seen all the installs. iIknow it is custom using the bezel and cutting the dash. But how or what is being used to brace the headunit to the dash for the double din?
Im almost certain that the JDM bezel isnt compatible with double din HUs. I dont think that its big enough. I could be mistaken, but I dont think so. Also, the JDM unit is angled, and I dont think that will make it easy for mounting.
i am doing the same eclispe doule din at the shop that you have in yours s4 play// with nav and satil radio.. awesome piece.. sure it will fit find since like you first said everything is custom.
The fitment on the JDM bezels is less then perfect. You have to customize that piece just to make it fit right and then you have to fill in the 1/4 inch gaps your going to have along the edges... then in the end its tilled toward the passenger a bit.
Not to mention that I don't think a regular DD HU will fit into the bezel so your have to cut the up just to try and make it fit.
i have read threw the post and talk to a friend he runs a audio shop in time and one of the best in the business when it comes to audio. i dont thing it will be that bad.. heres a link to his shop if you want to check out his work.. http://www.eliteaudioonline.com/
what i was really looking out is how you were building and attaching brackets to the inside of the dash.
i ment town opps.. and check out press room
http://www.eliteaudioonline.com/index.php?...=display&ceid=7
http://eliteaudioonline.com/index.php?modu...display&ceid=16
just a few more cars he build among the many.. what i;m doing is nothing compared to this stuff
