Installed shock sensor to OEM alarm today
I installed the DEI 504M shock sensor today and it is working good. When I read the instructions for the sensor it calls for a (-) only when the keys are out\ign off. I found 2 wires with my multi-meter that connect the alarm unit to the cars harness behind the drivers kick panel but am wondering what they are. The negative turns off when I slide the key in and as soon as I slide the key out it goes back on. The wire is black with a white(?) line through it right next to a red wire with a white(?) line (I used both for +\-). They are in the center of the plug that the alarm brain connects to. Are these the power wires for the alarm? Just want to be sure I'm not screwing anything up. I saw this list below already and it doesn't really define the wires well.
12volts white (x2) + ignition harness
Starter blue/white + L of column, lt blu 24P plug
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition black/red + ignition harness
Third Ignition N/A
Accessory white/red + ignition harness
Second Accessory N/A
Keysense red/white - ignition harness
Power Lock pink/black 5wi keyless entry module
Notes: The keyless entry module is located in the driver kick behind the start button.
Power Unlock yellow/green & pink/blue 5wi keyless entry module
Lock Motor pink/black 5wi keyless entry module
Unlock Motor yellow/green 5wi keyless entry module
Parking Lights+ red/black + keyless entry module
Parking Lights- blue - headlight switch
Hazards same as turn signals
Turn Signal(L) green/red + steering column
Turn Signal
Second Starter N/A
Third Ignition N/A
Turn Signal
S2Kmonkee
09-05-2010 10:48 PM
